2007 Polaris Scrambler for mud
Old Jun 1, 2012 | 10:25 PM
BubbaXXXL's Avatar
Default 2007 Polaris Scrambler for mud
I would like to set up my 2007 Scrambler to have more fun in the mud, does anybody know what I could do to increase ground clearance and improve tires without killing belts? I have only gone through one the whole time I owned the ride but I know some guys that have changed their clutches and killed belts all the time.
Old Jun 3, 2012 | 09:32 AM
Raven95150's Avatar
You can go a little bigger on the tires, but you aren't going to gain a whole lot there. The Scrambler simply isn't designed for serious mudding. If you want to do serious mudding, you will need a Sportsman or some other large utility quad.
Old Jun 3, 2012 | 08:46 PM
mrtwostroke's Avatar
well with the 500 fourstroke that has good bottom end. bigger tires will work. The
transmission from a xplorer 400 will give you low range.
either way with 25's you should walk all over the heavy bikes in muskeg/swamp riding.
In regular mud the heavy bikes aren't as much of a disadvantage.
different clutching will help the belt problems.
Old Jun 3, 2012 | 11:11 PM
lslubecki's Avatar
You can also use a trans out of a 2000 sportsman 6x6. That is what I did. I also went with 12x26" tires all around. The sportsman used 24" all around so the offset front to rear is a non issue. The sportsman also has a better low gear ratio to pull larger tires and heavier loads. I also lengthened my swing arm three inches. I wish I went with 28" now.
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
