08 Scrambler leaking???
Old Jun 17, 2012 | 07:49 PM
FL TRD's Avatar
Default 08 Scrambler leaking???
Hey guys i have a 2008 Scrambler 500HO and have been having this issue lately with water leaking into the plastic case where the clutch and belt are at. I use my atv in alot in deep water and mud and thought maybe the seal on the inside was bad so i changed it but still leaking have no idea where it could be leaking from so i filled the whole thing with water to see where it was leaking and couldnt find anything. But everytime i take into water deeper than the case it leaks and i get stuck because the belt gets wet and the bike wont move. Any thoughts?
Old Jun 17, 2012 | 11:16 PM
Welcome to the forum! If you just changed the outer cover seal,could be damage to the inner seal behind the front clutch. Plus there is a small rubber seal behind the rear clutch. Also check the rubber clutch air intake boot for any damage that could allow water to penetrate. OPT
Old Jun 18, 2012 | 05:32 PM
Raven95150's Avatar
The problem is they put the vent in about the worst possible place. I used to get wet belts all the time, so I came up with my own solution.
Now I can go in water up to the fenders, and I haven't once had a wet belt since doing this.
Old Jun 18, 2012 | 05:47 PM
TLC's Avatar
TLC
Like mentioned, if its not you intake or exhaust hoses to your belt housing, I will guarantee its the two seals behind the secondary and primary clutches on the belt housing's back plate. I just changed both on my 500.
It worked fine after that.
Old Jun 18, 2012 | 06:44 PM
FL TRD's Avatar
Cool ill have to check out those two seals on the inside, I also made a snorkle for mine the stock one was to low for sure but i checked everything in the front and it wasnt leaking from there so it has to those seals in the back
Old Jun 19, 2012 | 07:14 PM
tekrsq's Avatar
VERY nice !!! What kind of hose and size hose is that ? How'd you secure it to the clutch cover ?
Old Jun 20, 2012 | 08:54 AM
TLC's Avatar
TLC
The seals you may need are #4,#17,#18.
Old Jun 21, 2012 | 11:15 AM
Raven95150's Avatar
It's some type of hose that's used for pools and hot tubs, stuffed into a rubber sewer pipe fitting, which I secured to the cover with the original boot and clamps.
There wasn't a whole lot of planning that went into it, I just went to Home Depot and looked around until I came up with something that would work.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
wrencher82
Sep 24, 2015 03:39 PM
