Big Bear 350
Old Jun 22, 2012 | 01:25 PM
maxamy's Avatar
Default Big Bear 350
I could really use some help if anyone can... I recently acquired a Big Bear 350 ... mid 90's model and it was a basket case (so to speak) shifting mechanism messed up, carb shot, wiring issues etc...etc... I think I have most of it lined out but I'm stuck with something...I have driven it for several miles already and it ran OK but when I parked it it wouldn't start back... It's blowing gas back into the airbox...I take the intake off and hold my hand on the carb while cranking and fuel sprays all over my hand...I have adjusted the valves, all new carb components (jets, needle seat and valve, etc..etc..)
Now the problem seems to be fuel blowing back into airbox
Any help would be greatly appreciated...
Old Jun 22, 2012 | 02:51 PM
Jaster94's Avatar
get a compression gauge and perform the compression test. let's see what that comes back as. thumb test obviously returns skewed results
Old Jun 22, 2012 | 09:13 PM
maxamy's Avatar
I don't have one of those but I will ask around and borrow one...Are you thinking it could be rings? Is this a common problem with rings...It may take a couple days but IU will check and get back to you...Thanks for any help...I appreciate it... Max
Old Jun 22, 2012 | 09:19 PM
Jaster94's Avatar
just trying to help you rule out the expensive repairs first if all is good. it may be down to just a timing issue or another valve adjustment.
Old Jul 9, 2012 | 01:32 PM
maxamy's Avatar
OK ...I finally tested it...the compression was a little over 130 .... I would assume those are good numbers...I checked valves and they are within specs.... not sure what to do next...
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
