Linhai ATV goes dead
Old Jun 24, 2012 | 05:15 PM
NickinNC's Avatar
Default Linhai ATV goes dead
I have a Linhai 260 ATV that randomly goes dead and won't restart for hours. It normally starts and runs great for a while. It may run for an hour or two and then it just goes dead. The engine will turn over but it simply won't start. I started it one day and it went dead 50 feet out of the garage door. Any ideas what might cause this? Thanks in advance for any advice!
Nick
Old Jun 24, 2012 | 10:44 PM
LynnEdwards's Avatar
Electrical Expert
When the quad is refusing to start, do you have spark?
Pull out the spark plug, keep it hooked up, and hold the plug threads against the engine block. Turn all kill switches to the run position, and crank the starter motor. Do you see spark in the plug gap?
Old Jun 27, 2012 | 09:48 AM
NickinNC's Avatar
I checked for spark and there is not any. I tried it with a new plug and still no spark.
Old Jun 27, 2012 | 08:26 PM
Jaster94's Avatar
check the wiring under the plastics under the headlight/handlebar area. there are several items to check there. i had an intermittent problem with mine and i had a loose wire and a loose ground under there.
Old Jan 22, 2016 | 05:58 PM
outdoorsbound29's Avatar
Default Linhai goes dead
I'm just getting over having that same issue with my linhai and its a pain getting everything outta the way to check wiring under front cargo box area then finding nothing to be my issue. my problem was with the main hot wire from fuse box to solenoid was poorly connected. no more problems so far Honda man thru and thru but loves my linhai
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
