01 Warrior 350 Breaking Up at high RPM's
Old Jun 26, 2012 | 07:44 PM
Knust's Avatar
Default 01 Warrior 350 Breaking Up at high RPM's
Recently traded for a 01 warrior 350 it runs great until upper rpm then it sputters like its on the limiter. I know from the factory they dont have a limiter, but this has a procom cdi. I have chopped the plug it looks good k&n filter fmf exhaust jet is a 150. It will run 60mph in 6th gear before it happens. Any help would be great. thanks
Old Jul 3, 2012 | 10:03 PM
Knust's Avatar
Problem solved Thanks.
Old Jul 3, 2012 | 11:11 PM
crankestein's Avatar
Uh...
What was the solution?
Saying problem solved wont help at all others. If someone does a search with similar issues then they can use this thread as reference.
Old Jul 4, 2012 | 02:45 PM
Knust's Avatar
It had stripped exhaust studs, so the head pipe was loose causing it to lean out at high rpm's. Drilled and tapped in new studs tightened exhaust now runs perfect.
2quiker
Mar 22, 2022 08:36 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
