2003 Polaris Predator 500 Oil Pump
Old Jun 27, 2012 | 07:57 AM
mthornsen's Avatar
Default 2003 Polaris Predator 500 Oil Pump
I recently changed out the oil reservoir on my Predator and the process took longer than expected. My primary concern is that the oil pump may have lost its prime. Does anyone know if there is a way to determine if this has happened, or how to make sure that the pump did not lose prime? Any help would be greatly appreciated!
Thanks,
Matt
Old Jun 27, 2012 | 12:52 PM
Welcome to the forum! Just pinch off the oil tank vent line if in doubt about the oil pump when you crank it. This will cause the oil pump to prime up quickly if it has lost its prime. Oil pump and remote tank is similar to the Sportsman 500 and primes the same way. OPT.
Old Jun 28, 2012 | 07:12 AM
mthornsen's Avatar
Thank you for the advice, I appreciate it. I just want to make sure that I'm have the right line figured out. The vent line is the line that comes out the top of the oil reservoir correct? I've been looking online for a diagram of the oil lines and flow directions, but I can't seem to find one. Thanks again for the help!
Old Jun 28, 2012 | 07:31 AM
Yes the vent line is at the top of the tank. OPT
Old Jun 29, 2012 | 07:13 AM
mthornsen's Avatar
Thanks again for the help. Your tip worked like a charm and I'm ready to hit the trails again! Thanks!
Jmuddin284
Jan 19, 2026 07:16 AM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
Mikea1978
Jul 4, 2015 12:37 PM
