02 kawasaki 650 2/4wd flashing
Old Jun 30, 2012 | 02:44 PM
stillahondafan's Avatar
Default 02 kawasaki 650 2/4wd flashing
recently i noticed i have dreaded 2/4wd flashing back and forth.. seen other posts with simaliar problem.. but in my case i notice i do not hear that lil noise that you hear when you turn your key on and off.. theres just nothing so was wondering if its the engine brake actuator and not the 2/4wd cause it will engage both to 4wd and 2wd..
Old Jul 2, 2012 | 12:43 PM
Hayashi's Avatar
Yes it is the engine brake acutuator that has gone bad according to your own descripton. Water gets inside the actuator and messes it up.
Old Jul 2, 2012 | 07:33 PM
Default thxs
curious what the price of one of them would be ?
Old Mar 22, 2013 | 02:36 PM
Hayashi's Avatar
Dealer sells a new one for $300+ (ouch!).
You can buy an used for about $100 or even less from eBay but you need to be careful. It may not have any visual damage/defect outside but can still give you the same 2/4wd light flashing problem. If you get some kind of assurance that the item is good from the seller (like no hassle money back), then it might be ok.
Old Mar 22, 2013 | 03:20 PM
TLC's Avatar
TLC
May want to read his link before dishing out any money. Nyroc's ATV info website
Old Apr 14, 2013 | 04:57 PM
mwaak2064's Avatar
Default Bad Wire
I just wanted to share my findings.
After following the manual and testing everything in it that could cause this, replaceing every part because the issue continued. Even went on line and read... did the buss connection... still the problem was there... after several hundred dollars on parts and many days of testing per the manual, i desided to test the continuity of all the wires from the controller to the actuators. this is very simple to do all the wire colors are in the manuel and easy to locate. I had simple ..... bad wire..... went to the auto supply, purchased two inline splices for #16 gage wire and about 3' of some number 16 gage wire.
The wire i could not get any cont. on was the Black/red tracer. this is the ground for the break actuator. This took about 30 mins to test and replace, and only cost me 3 dollars. But hey, I now have both actuators new, new controller, speed sensor, Forward and Reverse sensor. I just thought i would put this out there hoping to save someone else all this expence. And if anyone needs any of these parts...because all my original parts are all good.
Old Apr 18, 2013 | 09:43 AM
Hayashi's Avatar
I just checked the electric schematics forthe Brake Actuator and there is no such Black/Red wire. There are total 5 wires to the Actuator.
Red
Black
Orange
Yellow
Blue
And the Black is ground but it doesn't have red stripe, just solid black. ???
vandammages@gmail.com
Aug 20, 2020 11:50 AM
ReconBayou
Oct 16, 2019 02:24 AM
exmotocrosser
Sep 26, 2015 08:18 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
