04 700 maintenance question
Old Jun 30, 2012 | 05:42 PM
Polaris2004700's Avatar
Default 04 700 maintenance question
I have a 2004 1/2 700 Sportsman. I bought it when it had 100 miles on it. It only has 715 now. I just did an oil change using Amsoil ATV 0W-40. I've never changed the differential or transmission fluid. Would you guys recommend also using Amsoil products for these or are the Polaris fluids decent enough.
Any input is appreciated.
Thanks.
Old Jul 1, 2012 | 10:34 PM
On the transmission I would stay with Polaris AGL or if you can find an equivalent oil for chain driven gear cases and you'd rather use this then it should be ok. For the rear differential any 80/90 GL5 is ok. The front differential I would use Polaris Demand Drive fluid only! Just my OPT
Old Jul 2, 2012 | 04:33 PM
switzomatic's Avatar
X2 on the front diff fluid. Heard a lot of others using other stuff in the motor/tranny/rear diff but anything other than demand drive on the front will give you issues.
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
caveeagle
Sep 19, 2015 01:20 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
