2001 Yamaha Blaster Rear Brakes
Hi,
I have a 2001 Yamaha Blaster and having issues with the rear brakes. The caliber is not closing when pressing the foot/parking brake. The cable is working well as well as the pedal.
Is there something within the caliber that would prevent this from happening?
Any information would be much appreciated.
Thanks,
IronBear
Thanks,
IronBear
Hi,
Thanks,
IronBear
Thanks,
IronBear
the old cable brakes they used on the rear are crap imo they constantly need adjustment(almost every ride) you can clean an adjust them or with a lil work you can convert them over, the 2003 an newer had the better brake setup and its all a direct bolt on except the pedal an resi
i would say i spent about $200 for the conversion $40 for the carrier $60 for the banshee axle(widened it by 3") and about $100 for the brakes an misc. parts to make it work i bought it a lil at a time untill i had what i needed
I'm probably even missing more parts... like the rear rotor is different as well..... along with the hub for it is a solid mount instead of a floating rotor.... I'm not a fan of the floating rotor, but like I said... it works if you keep up with it and maintain it right... it's really not that hard to work on or adjust... it just takes a few minutes once in a while..... Maybe mroe parts too.... I have everything to convert mine over... including a frame and pedal and swing-arm, and rear bearing housing, axle all of it.... If you live nearby, I'll sell it all to you if you want.... It's just money.
Sorry.... I just read your Location and realized I have no location listed... I'm in North Texas.... not a real convenient situation for parts swapping.... but We can talk if you're interested.... PM me....
Thank you for all your responses. Do you know if 'rebuild kits' are available for the stock brake setup?
I need to get these brakes fixed ASAP as I'm doing a MT Washington (highest mountain in New Hampshire) ATV ride in a few weeks, and brakes are a must.
A new caliber is close to $200.00 and I'm not spending that kind of money.
If someone knows of a place where I can get a rebuild kit, with instructions on how to install it, then that would be great.
IronBear
IronBear
IronBear
IronBear
Unless you've just cobbed the caliper up rally bad, you should be able to take it apart, clean it up, re-assmble it with maybe a new seal or something to keep dirt out, and be fine, once you re-assemble it and adjust it.... You can buy every part of it through Yamaha, including a new cable.... I'd recommend finding the aftermarket Brake cable that eliminates the part to the Handle Bars though.... Usually a better cable and only one connection point to deal with. Go to the Sport motorcycle pages on the Yamaha Motorcycle web site, and look for the parts and service links..... find the catalog section and look up any parts you need... that can't be found elsewhere. It's really that easy.
UPDATE!
I had to use a file and wire brush to hone the brake pad hole so that the brake pad would fit properly. Before placing the pad into the caliber, I greased the inside of the hole, and outside of the pad, but the pad is still tight.
Once the aftermarket cable comes in, I will then install the caliber and hopefully, this time the brakes will finally work.
