sportsman 800 ...no cold idle...help!
Old Jul 3, 2012 | 02:33 PM
gixxerone's Avatar
Default sportsman 800 ...no cold idle...help!
Its a 2006 sportsman with 1100 miles and when its cold it idles really low to almost stall then once warmed up it runs great and idles about 1100 rpm......Any info would be helpful.....thanks
The only thing i did was clean carbon from throttlebody .
update...
Now i replaced the bap sensor and it still has the same problem(no cold idle)...I'm going to check codes now and see if anything is stored.....no codes and the ect is at 1.6k ohms at about 80 degrees. The wires at the map sensor seem to be ok...Any other suggestions? Any help at all is appreciated.
COFatboy
May 2, 2020 12:06 AM
mtdewmn
Jan 19, 2017 12:13 PM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
theddaug
Aug 15, 2015 09:17 AM
ltrmc02
Jul 22, 2015 04:50 AM
