yamaha blaster or yamaha warrior
My son, 13 years old, rides a yamaha warrior he is a pretty skilled rider.. he wants to get some after market parts for it. i dont know if a blaster will be just as fast or faster than the warrior. i know there are tons of aftermarket parts for blaster and frankly it be safer if he rode a blaster so the question is shuld i keep and upgrade the warrior or sell the warrior and get a blaster upgrade it?
I would keep the Warrior. In my opinion the Blaster is a step down. The Blaster is not as powerful or torquey as the Warrior and the suspensions on the Blasters suck even worse than the Warrior suspensions do. A stock Blaster will run about 55 mph top speed, same as a Warrior. A 400EX would be a better option than a Blaster or modding the Warrior. I'm not sure why you say a Blaster is safer than a Warrior?
It would take a big bore kit to make any noticeable power on the Blaster. You wouldn't gain much from just boring it over a few thousandths. But that still will have no effect on the terrible suspension or the horrible brakes (pre-'03). My buddy had a '03 Blaster that I would ride sometimes and it had a shaved head, Vito's degree key, Toomey pipe, jetted, air filter, and a reed spacer, most of which was supposed to help with bottom end torque, but it still barely had enough torque to get me up a steep creek bank. Plus the suspension felt like that on a lawnmower. Granted I am 6'-1" tall and 220 lbs, but the Warriors that I have owned never failed to carry my big self through anything, the brakes are better, and the suspension is better. Plus you don't have to buy that expensive 2 cycle oil for the Warrior - just pull up to the pump and fill-er-up!
Both blaster and warrior are unique models and contribute same too... you should upgrade and ride both !
My blaster is bored .60 over, it has some get up and go, but its a bit scarey with terrible brakes and suspension. Still not that fast though.
I say the 400ex is good, but i had better luck on my 300ex.
Would be worth finding and test riding a few of each on craigslist.
Cant speak for the warrior though..
I've got a Blaster that's bored 60 over as well....
Mine is quite peppy. I also put slightly smaller tires on it (Though wider), and a Used FMF gold series pipe and Can...... Woke it up BIG TIME.... nothing else is modified as far as performance mods, and I have more than I can handle in the Trails..... It's fun, but it's also a lot more work than the 4 stroke Warrior is..... The torque is all in that Screaming Power band.....
My machine runs about top end of 50-53 MPh.... if that aint fast enough, then maybe another 4 wheeler is a better choice. 50 is plenty fast for a trail riding machine I think....
