2003 kfx80 help
Old Jul 11, 2012 | 09:03 PM
skeets44's Avatar
Default 2003 kfx80 help
It has a problem starting when motor is cold, It will start very easily when cold if you slip off the intake from carb and place your hand over the hole and pull start.. 1st pull 95% of time. It only takes an extra 10 seconds to do this when the motor is warm it will start like any normal atv
this is part of an add they are looking for 700 for this. any help on what could be the cause of this
Old Jul 20, 2012 | 11:33 PM
TrevorB1's Avatar
Sounds like a jet is clogged. check the compression if its good the only other option is the carb. I would clean it real good and see what happens.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
