Bigger tires killed my low end torque..suggestions?
Old Jul 17, 2012 | 07:44 PM
Riddler77's Avatar
Default Bigger tires killed my low end torque..suggestions?
I have a '08 Sportsman 300, same as the Hawkeye, and it came stock with 22" tires. I recently installed 23" tires and my low end torque decreased dramatically. I expected a little decrease, but its really noticeable. I checked if they make an aftermarket clutch kit for this model, but they do not. What else can help me increase low-end torque? Exhaust?
Old Jul 17, 2012 | 08:05 PM
Kinda of limited by the Eton clutch system as far as any upgrades there,plus the 300 was only produced 3 years,but if other owners have made any performance improvements hopefully they will post their results. OPT
Old Jul 17, 2012 | 08:09 PM
95wolv's Avatar
You can probably make your own "kit" by checking what style weights are used in your primary clutch, and see if you can find matching ones in a lighter weight, or find a primary spring one or two steps stiffer than your factory one. Same with the secondary, find the specs on it, and see if there is one with slightly higher compression/weight settings and go from there. I dont know if the quad clutches are the same as the sled ones, are there multiple holes on your secondary? you can use those to tune your secondary a bit before changing springs. Never messed with a Polaris quad clutch, but have done a bit with Polaris sleds,if they are similar, should be pretty easy to tune it to your needs. Check with Aaen performance and see if they have any recommendations, even if no pre made kit is available, you should be able to swap out springs and weights to get what you want.
Dang, just saw OPT post the clutch isnt the same...so I guess my idea is pretty useless.......
Old Jul 17, 2012 | 08:55 PM
Riddler77's Avatar
Thanks guys. I know the smaller quads are kinda limited with the upgrades available. I am 6' 2" so maybe its time for a full-size quad! My buddies always razz me about it. Keeping my eye out for a 500 or larger.
Old Jul 17, 2012 | 09:00 PM
95wolv's Avatar
Going from that mild 300 to even a 500 would feel like jumping off a pony and grabbing hold of a Brahma bull....lol. That quad is very heavy for a little motor like that, and if you are a big guy, you are probably pushing that little motor to its limits, bigger tires just magnified that.
Old Jul 17, 2012 | 10:39 PM
95wolv's Avatar
so.......you copy part of my post and send me links to other web sites....just who are you
Katherinjjm?
Old Jul 18, 2012 | 06:09 AM
Riddler77's Avatar
Agreed 95wolv, this quad takes me where I want to go, just not very fast. Just need to find the xtra money to go bigger.
Old Jul 18, 2012 | 06:43 AM
95wolv's Avatar
Hey, my first quad was a Yamaha Moto4 200........same thing, got me there, and was actually pretty good in tight woods trails. but down on power for hills and such.
Old Jul 18, 2012 | 06:44 AM
ATV suzuki Dude's Avatar
try a larger rear sprocket or smaller primary sprocket...or both.. i dont know to much about a sportsman quad but if you cant find a sprocket that will fit you may have to use your old sprocket as a templet for drilling a new bolt pattern
Old Jul 18, 2012 | 07:58 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
hehe-
it's a sportsman, not a sport quad-
no sprockets
the best way to increase the power of a 300 is to buy a 500
