Rear axle problems:
Old Jul 28, 2012 | 07:05 AM
lumpfish's Avatar
Default Rear axle problems:
Just wondering if anyone can help me on how to get a rear axle out of a 2004,400,Polaris Sportsman?I am just about to the end of my string,trying to get it removed.I've even pounded on it with a 14 lb hammer and a piece of pipe.
Old Jul 28, 2012 | 09:42 AM
Welcome to the forum! Sometimes it takes heat, penetrating oil (PB Blaster is the best I've used) plus helping hands to hold the atv while someone does rapid jerks on the drive shaft to try to pop it out. Just takes some time on some atvs. I've even used slide hammers on some tough ones.The shaft splines on the axle can get dirt and grit on em making them tough to remove. OPT
Old Jul 29, 2012 | 03:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the polaris forum. the little spring clip in side that holds the shadt in place sometimes gets all rusty and muddy and can be a bear to get out. as mentioned soak the helll out of it with penetrating oil and it should snap out, maybe with a little prying as well.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
