adjusting suspension on sportsman
Old Jul 28, 2012 | 11:12 PM
cbrandon's Avatar
Default adjusting suspension on sportsman
I've been wanting to adjust the rear suspension on my '11 500 and I can't figure out what tool to use. What in the world do you guys use to tighten it.
Old Jul 29, 2012 | 08:05 AM
Your tool kit should have a shock spanner tool with an adjustable sleeve. If you don't you can always wrap the adjuster collar with an old shop towel to keep from scarring things up and use a pipe wrench. Best to remove the tires to where you have easier access and keep it jacked up to take the load off the spring while turning the adjuster. OPT
Old Jul 29, 2012 | 10:54 AM
cbrandon's Avatar
Ok I will try the pipe wrench with a towel. My tool kit has nothing in it that will work I tried everything in it every way I could think of. If I contact my dealer can I get the tool for future use, or would they even have it?
Old Jul 29, 2012 | 11:58 AM
Dealers could have em or order for you along with a lot of online suppliers. OPT
Old Jul 29, 2012 | 12:02 PM
cbrandon's Avatar
Ok thank-you much.
Jmuddin284
Jan 19, 2026 07:16 AM
Reactant
Mar 30, 2022 02:08 AM
Nondem
Feb 22, 2020 12:20 PM
Jul 21, 2015 03:03 PM
Jkfx400P
Jul 6, 2015 10:04 AM
