Front axle removal
Old Jul 29, 2012 | 12:29 AM
Dayle N's Avatar
Default Front axle removal
Hi just wondering how i remove the front axle.Ive read elsewhere you should jus be able to pull it out.Ive done that and tried prying only with a screw driver.Is there a trick to these or i need a big pry bar thanks
Old Jul 29, 2012 | 07:05 AM
Tonyxp's Avatar
They get kinda stuck in there. Try soaking it with a penetrating oil for a few days. If the axle is junk go rent a slide hammer or make one. Weld something to the cup or yoke and give it a tug. Sometimes you have to secure the bike to the work bench or pick up so it doesn't fall off the jack stands. When you reinstall one put marine grease or anti seize on the splines. Good luck.
Also on the front diff it doesn't go through like the rear does. So don't try removing the other side and knocking it out. You will wreck the diff
Old Jul 29, 2012 | 03:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there is a sticky post on the "ask an expert" section on how to remove the cv shaft. some times theycan be tough.
Gtsordo
Jul 13, 2015 10:38 PM
Rider252
Jul 6, 2015 03:37 PM
jettman
Jul 6, 2015 12:16 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
