Stator broken no name atv chinese where to =get a new one?
Old Aug 19, 2012 | 08:02 PM
trieck1232's Avatar
Default Stator broken no name atv chinese where to =get a new one?
may have figured out the no spark, well .07volt spark stator is broken off..
here is a picture
https://sphotos-a.xx.fbcdn.net/hphot...87494063_n.jpg the black piece is siting where the cover goes over the timing chain to the top right, where do i buy this is it
Stator Magneto 03 for Chinese 50-70-90-110cc Engines - Sm272-03 - 50cc - 125cc Stators - Stator Magnetos - Electrical Parts - In Stock at Sunlpartsonline
https://sphotos-a.xx.fbcdn.net/hphot...28975860_n.jpg
looks like some rubbing on the flywheel, do i need to change that too??
here is the atv i had a post earlier today, I dont know the make or model it is chinese... think its a 90 as the head says 10cm3 on it...
pic of the quad.. https://sphotos-a.xx.fbcdn.net/hphot...55334298_n.jpg
Old Aug 19, 2012 | 08:05 PM
trieck1232's Avatar
also what lube is recomended it is a bit dry inside on the timing chain
Old Aug 20, 2012 | 11:57 PM
LynnEdwards's Avatar
Electrical Expert
Well if the timing trigger pickup coil is broken you won't get spark...
I've never owned a 110cc (or whatever displacement) E22 engine powered quad. So I don't know a lot about them. AS far as the pickup coil, usually these come as part of a stator assembly, and are riveted onto a base plate with the other two internal coils (AC ignition power, and battery charge windings).
To buy a new stator I would look extremely carefully at the mounting scheme (comparing pictures from the vendor website to yours). Also I would look very carefully at the battery charge winding (the one with heavy gauge wires), and see if one end of the winding is grounded to the case. There are two different topologies of stators aout there, and you need to find out what yours is before looking for a replacement.
AS far as rubbing on the flywheel, I would be concentrating on *why* the rubbing was taking place. This should not be happening at all. I'm wondering if you have a bent crankshaft, or something else that would cause the flywheel to wobble as it turns. This would be very bad. The gaps between the internal flywheel and the generating coils is very small, as is the gap between the external pickup coil and the *raised bump* on the outside of the flywheel. We're looking at clearance numbers like 0.025". You've managed to break off the external pickup coil *and* score up the inside of the flywheel pretty bad. This first question is not whether the flywheel is good or not, the question is *why* this happened. That needs to be solved first (and before you buy a new stator). I would use a dial indicator to measure the flywheel runout as the engine is turned by hand.
Old Aug 21, 2012 | 06:19 AM
trieck1232's Avatar
Will do thAt tonight! The guy that had it before me was clueless, only had 1 of the stator housing bolts on when I got it, he probAbly tried to start it like that, however I will do some checking into the bent crank!
Old Aug 21, 2012 | 11:07 PM
Electrical Expert
One bolt out of two would explain it. With only one bolt the stator can twist around the single bolt and collide with the flywheel. That seems more likely a scenario than a bent crankshaft.
Old Aug 22, 2012 | 06:37 AM
trieck1232's Avatar
Crank seems ok checked it wIth a pen Mic all within .005 as it turns new stator comes in today!
Old Aug 22, 2012 | 10:54 AM
46u's Avatar
46u
That is not a timing chain it is the starter chain and there is no oil in that compartment I do not think. Would not hear to lube the chain with some good chain lube let it set and then wipe it off.
ultangler
Nov 30, 2024 01:35 AM
fredrikrosen
Oct 29, 2016 07:56 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
johnny1982
Sep 13, 2015 07:41 PM
