Grease points
Old Aug 20, 2012 | 04:34 AM
Dayle N's Avatar
Default Grease points
Hi could someone tell me how many grease points there is on a polaris twin sportsman.Its an 04 model and i have only found 2 and that was on 2 shafts.Thanks
Old Aug 20, 2012 | 01:47 PM
switzomatic's Avatar
Owner's manual will tell you for sure but if I remember correctly there is one on the front/rear prop shafts, upper/lower a-arms front and rear, and one on each side of the front lower struts for the lower ball joints. It may have some on the prop shaft u-joints also if they were replaced with aftermarket ones. Some were grease-able but if I remember right oem's were not.
Old Aug 20, 2012 | 02:43 PM
SOLOLUCKY's Avatar
For sure check all over yer suspension A-arms, at the frame mounting and at the lower "ball" joints.
Thats really all there is on them...suspension and drive shafts.
now my 2003 330 magnum has greasable driveshafts and U-Joints but the suspension has NO grease fittings...none front nor rear..its kinda of sad that such a vehicle would have zero grease fittings...its all still tight but I have done some serious water stuff with it over the years and sure would like to pump some grease in'em
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
bigred20653
Oct 2, 2015 10:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigred20653
Sep 19, 2015 02:11 PM
