honda 110 atc carb. problem
Old Aug 21, 2012 | 04:23 PM
gyroman's Avatar
Smile honda 110 atc carb. problem
My 110 sat for 10 years and when i put gas in it the gas would keep coming out of the little rubber hose on the bottom of the carburetor.
I took the carb apart and cleaned it but i have the same problem even after 2 more cleanings. Do i need a rebuild, new carb or some adjustment neeeded? Thanks for any info.
Old Aug 23, 2012 | 12:19 AM
MIsuzukilt230s's Avatar
First check to make sure the drain screw at the bottom of the carb is seated all the way in.
Is the float plastic or metal? I can't remember if the float height is adjustable on these...
How exactly did you go about cleaning the carb? Is there a lot of rust in the gas tank?
If it sat for that long it wouldn't be a bad idea to rebuild it. You can order a rebuild kit on ebay.
To be honest I wouldn't even bother with it. You can pick up a brand new carb on ebay for roughly $35. A rebuild kit is going to run you about $20 so for a little more you can get a whole new carb.
If you go with an ebay carb, make sure to pull the bowl off and make sure the jets are tight...other than that I have had good luck with them. I have one on my 110 and one on the 200s.
Being that these bikes have a metal gas tank I run an inline filter in the fuel line to help catch any debris that can result from rust in the tank.
Good luck reviving the 110!
Old Aug 23, 2012 | 10:31 PM
gyroman's Avatar
Default To MIsuzukilt230s
Thanks a million for your reply. The drain screw was open and letting the gas drain, i must have opened it to drain the carb when i put it away and left it open. The gas tank is good and i cleaned the carb with carb cleaner. Without your post i was stuck, thanks again.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
generalpops
Jun 5, 2015 08:23 PM
lovinhonda
Jan 25, 2000 09:17 PM
