Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
E-Ton viper 90r no spark
Old Aug 22, 2012 | 12:09 PM
HonkyTonkPA's Avatar
Default E-Ton viper 90r no spark
my son just picked up this quad. i checked the wiring( continuity from terminal to terminal) using a wire diagram from the eton site. got it all back together, will turn over, but will not start, no spark. What should i check and how (pics would also help)? thanks
Old Aug 22, 2012 | 12:23 PM
Jaster94's Avatar
so the thumb kill switch checked out OK? does it have a rear tether umbilical kill under the seat towards the rear? so you've pulled the spark plug, grounded it against the jug/cylinder with the coil wire attached and cranked it and checked for spark? right?
Old Aug 22, 2012 | 01:33 PM
kill switch checked ok. does not have teather. just check again. will spark for a secound or two, then quits. if you turn key off then back on will do the same.
Old Aug 22, 2012 | 05:08 PM
Jaster94's Avatar
let's go for the easy try now, change spark plug to the NGK brand. parts store ought to be able to cross reference whatever you got.
Old Aug 22, 2012 | 05:13 PM
it is an NGK plug
Old Aug 23, 2012 | 12:16 AM
LynnEdwards's Avatar
Electrical Expert
How many wires on your CDI?
The wiring diagrams I've seen for viper 90cc quads with reverse has a *lot* of wires on the CDI. Is this the case with your quad?
If so I can't help. The CDI is a multifunction device that does a lot more than generate spark. Unfortunately there is not enough info from the published diagrams to figure out what those functions are, and how they interact.
Old Aug 23, 2012 | 11:42 AM
has somewhere around 20 wires going to the CDI
Old Aug 23, 2012 | 11:43 AM
how can i test the other componants to make sure they are in working order. ie: coil, stater
Old Aug 23, 2012 | 04:32 PM
beyondupnorth's Avatar
Is this 2 stroke?
Perhaps a manual for the Polaris sportsman 90 could help, Uses the same engine I believe. They are know for having stator issues with the 2 stroke.
Free Cloud Storage - MediaFire
Download free at this link, and do the stator tests.
Ken
Old Aug 23, 2012 | 04:49 PM
yes it is 2stroke
