97 sportsman 500 carb in need of rebuild? cost?
Old Aug 24, 2012 | 04:51 PM
mad-atver's Avatar
Default 97 sportsman 500 carb in need of rebuild? cost?
my 1997 sportsman 500 has no power and it only does 30mph and can't spin the tires at all. we put the carb off my dads 99 sportsman on mine to see if it was the problem and it worked great with that carb. we cleaned my carb over and over, cleaning all the jets and adjusting it, but still no luck. my dads a mechanic and it baffles him. do you think i need a carb rebuild? my dealer charges $85 an hour but i don't want to spend hundreds of dollars, how quick would they be able to find the problem?
Old Aug 24, 2012 | 05:34 PM
Moose carb kits are a pretty complete kit and fairly reasonable. Moose Utility Division - Product Catalog The only thing that they don't supply in the kits are the float arm and float pin which a lot of people don't bother to replace. If the float arm is worn and wobbly best to replace it also as it can cause problems even after a carb rebuild. This place is about as cheap as any online for these two items. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
Old Aug 24, 2012 | 05:38 PM
mad-atver's Avatar
how long would it take a dealer to go through the carb and replace the worn parts?
Old Aug 24, 2012 | 05:53 PM
Probably charge you between 1 to 1 1/2 hrs depending on the dealer PLUS dealer priced parts which are high! Kits are the best way for the do it your selfers,the only high priced item is the float arm assy on your model($45 at Cycle Parts Warehouse) IF the float arm assy is wobbly and worn and needs to be replaced.A lot of people tamper with this also,adjusting up and down when they have problems when just replacing it would solve a lot of the carb problems along with the carb kits. You can rebuild it for at least 1/3rd of the cost a dealer would charge. OPT
jgiljr
Aug 21, 2015 06:15 AM
gfl0224
Jun 27, 2015 06:52 PM
DOAinNY
Jun 11, 2015 10:34 PM
brinkkl2000
Jun 11, 2015 12:46 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
