My 2012 RZR 800 Caught Fire !
Old Aug 25, 2012 | 08:55 PM
corvette72011's Avatar
Default My 2012 RZR 800 Caught Fire !
I have recently put a HMF swamp series exhaust on my rzr 800. Has maybe 100 miles on it, but I've not ridden it more than 15 minutes, until today, after riding bout 20 minutes a friend stops me and says my header pipe is cherry red. Then after riding another 5 minutes my bed catches fire! I've not reprogrammed, but when I bought it, HMF told me to try it, it may not need reprogrammed, it was running fine, but something has to be wrong. Ideas?
Old Aug 25, 2012 | 09:09 PM
Welcome to the forum! Running way too lean!! Needs to be reprogrammed. Can do more than just catch the bed on fire,can cause engine damage if you don't. OPT
Old Aug 25, 2012 | 09:20 PM
Thanks, kinda thought I might have to....
Old Aug 31, 2012 | 03:37 PM
biz4two's Avatar
Arrow
...agree with OPT. Just about anytime adding a new exhaust system...the engine should be mapped correctly. HMF has the Optimizer...and is a good system. While you are at it...might want to add a free flow air filter too. Something like UNI...
Good luck!
biz
Old Sep 1, 2012 | 05:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to polaris forums. your running alot more free air flow w/ the exhaust so it would require more fuel to help richern it back up to keep it cooler burning.
Old Oct 10, 2012 | 11:20 PM
haywire17's Avatar
where can you get reprogramming done at
Old Oct 11, 2012 | 09:27 AM
Reprogramming (or remapping) for Polaris is through Polaris Digital Wrench software that Polaris dealers(or independent shops) are required to purchase.Not available to the general public that I'm aware of. (that may have changed,but doubt it) https://polaris.spx.com/DisplayByCat...x?cat=1&sub=23 OPT
Old Oct 11, 2012 | 07:21 PM
bad87gn's Avatar
It may not be just the programming. Exhausts that fit the 2008-2010 RZR will generally not fit the 2011 and newer. They changed the head design and the exhaust will be way too close. I'd get the stock exhaust back on - that HMF adds nothing but noise.
Old Oct 12, 2012 | 08:05 PM
WilliamBos's Avatar
I agree totally!!
I thought the advantage of EFI was that it would make the changes needed on it;s own?
Old Oct 13, 2012 | 01:04 AM
The ecu on efi machines can compensate for subtle changes in the engine as it wears and accounts for this,but any drastic change to the intake or exhaust system is more than it can handle and most cases has to be remapped to allow for the changes.You can also get into power commanders,just depends on how radically you change the system. OPT
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
greg74
Sep 10, 2015 07:58 AM
