Need help with electrical, KLF300B Bayou 98
Old Aug 30, 2012 | 12:43 AM
Lisa Stewart's Avatar
Default Need help with electrical, KLF300B Bayou 98
Hi everyone, I have a prolem in which we can't figure out, after having stored my 98 bayou 300 2x4 we was having to get a new battery for it but wanted to make sure it would start and run before getting it so we hooked jumper cables to the battery on a vehical not running and started it. It would not stay running without a good battery so we bought a new battery and replaced the bad one. Now the problem we have is there is no lights coming on or anything after replacing the battery Any ideas what is going on with this, the fuse is good in it.
Old Aug 30, 2012 | 08:19 AM
Jaster94's Avatar
you've tested the fuse with a multimeter/ohm meter or just looked at it? terminals tight? check the wiring on the backside of the keyed ignition switch.
Old Aug 30, 2012 | 01:53 PM
New fuse and tested, no current to the starter and no current to the ignition switch.
Old Sep 9, 2012 | 10:08 AM
papa hogg scoot's Avatar
Loved
Community Favorite
The bayou IMO are common for bad starter inhibitor relay going bad...small black box beside of the solenoid switch...May try to tap it an lil bit to see if current will go thru it.....
Old Sep 9, 2012 | 11:43 AM
Thank you will try that and see what happens, just received my service manual also so hope I can get this going without having to take it to the shop. Will let you know what happens afterwards.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
