What Oil Ratio does Polaris Trailboss 250cc injectors run at?
Old Sep 3, 2012 | 10:56 AM
mlhend2002's Avatar
Default What Oil Ratio does Polaris Trailboss 250cc injectors run at?
Hello all,
Just wondering what Oil Ratio does Polaris Trailboss 250cc injectors run at? Also, are they reliable or should I disable (how?) and premix? I'm running AMSoil Dominator which suggests 50 to 1.
Thanks,
Mark
Old Sep 3, 2012 | 04:24 PM
They are normally reliable and are a variable speed oil delivery pump that are supposed to be calibrated around 50-1 ratio. A lot of people are afraid of auto injection systems,but can't remember when (if ever) I really found a bad one over the years.(EXCEPT on the 400 engines,the oil pumps that would corrode up from water mainly because of their location at the front of the engine) The main problems on any pump were people not bleeding pumps(small bleed bolt at the top) to remove any air which could cause problems. OPT
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
binky79
Jul 30, 2015 06:37 PM
Ashley S
Jul 30, 2015 08:38 AM
kdg723
Jul 25, 2015 01:20 PM
