01 scrambler 90
Old Sep 3, 2012 | 12:30 PM
raman8tor's Avatar
Default 01 scrambler 90
hey there my son has a scrambler 90 and im having some carb issues. the wheeler will start and idle, but dies as soon as i hit the gas. if i put my hand over the carb as to choke it out, it will run great. ive cleaned the carb and tried adjusting it but nothing changes. any ideas what the problem could be? thx!
Old Sep 3, 2012 | 04:30 PM
Have you replaced the float needle? Have you blown out the main jet and pilot jet also, and made sure the small opening in the float bowl is open? Plus there is a small tube with a red plug on top of the carb that sometimes splits and could cause it to run lean. OPT
Old Sep 3, 2012 | 06:11 PM
raman8tor's Avatar
i have not replaced any parts in it. i did blow everything out tho. and i will check that tube. thank you!
Old Sep 5, 2012 | 06:50 PM
raman8tor's Avatar
so i cleaned the carb again, blew everything out, and checked that tube. it now comes out of the hole good, but falls flat shortly after. the air/fuel screw is almost all the way in.
Old Sep 8, 2012 | 08:42 AM
Air screw should be about 1 to 1 3/8 turn out. Check that the tank vent into the three way valve is open. Could be having a vacuum lock. Look here under your model on the fuel tank. Browse OPT
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
