Jumping out of gear
Old Sep 6, 2012 | 07:34 AM
a65thor's Avatar
Default Jumping out of gear
I have a 2004 Trail Boss 330 that is in decent shape, but often jumps out of gear. It seems to do it most often when not under load-going down hill or slowing down. Is there any adjustment that might help this, or am I going to need to find a used transmission for replacement?
Old Sep 6, 2012 | 07:51 AM
TLC's Avatar
TLC
If its like a sportsman there is two linkage rods from the shifter to the tranny with adjuster and lock nuts,one rod is for foward and the other is for reverse.
Mine did that and just a little turn of the adjuster fix it.
Old Sep 6, 2012 | 09:17 AM
a65thor's Avatar
Thanks, but the Trail Boss only has one rod connected to a bell crank. I've adjusted it so there's no body work or anything else that's in the way, so it goes fully into gear.
Old Sep 7, 2012 | 02:48 PM
If you've adjusted the shift linkage,belcrank is tight,etc, then could be worn lugs on the slider gear or drive gear in the gear case that could be causing it to jump. OPT
Old Sep 8, 2012 | 07:47 AM
a65thor's Avatar
Thanks --I haven't been inside the gearcase. Are these parts that can be reasonably replaced?
Old Sep 8, 2012 | 08:24 AM
Cheapest online places are Cycle Parts Warehouse and Cheap Cycle Parts.Look at their breakdowns on the gear cases. If it is internal gear problems the gears can run from $40 and up depending on what needs to be replaced along with the seals. Plus it could just be the internal silent chain actually jumping teeth,causing the problem? OPT
Old Sep 9, 2012 | 07:40 AM
a65thor's Avatar
Thanks for the help. I'll pull the gearbox & take a look inside.
skinnyr6
Aug 25, 2023 02:18 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
black_thunder
Jul 26, 2015 09:23 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
