Raptor 350 Engine Noise
Old Sep 6, 2012 | 11:58 AM
hrdRoller's Avatar
Default Raptor 350 Engine Noise
How it going everyone, im looking for some help with my friends 06 raptor 350. It started ticking after doing an oil change, i did the valve adjustment and the ticking is still there, i double checked the valve clearances and it was with in specs. Someone mention it might be the timing chain so i was going to try and look into that. I have the service manual for the quad but need the repair manual. I tried buying one from Ridenow Motorsports but they sold me the wrong one and wouldn't return it. Thanks for your help
Old Sep 14, 2012 | 08:01 PM
Four Stroke Tech's Avatar
That motor is the same as a Warrior and one of the first things to go out of them is the bottom end rod brg.
That's the biggest reasons I built Oil Cooler kits that you drill the clutch cover for the fittings. I see a lot of people that have copied my kit but they don't even know why I built it the way I did. This way pumps the 50* cooler oil into the end of the crank to put the coolest oil where it will do the most good,making the engine last a lot longer.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
D-Hagz
Jul 4, 2015 02:19 AM
