2010 rail lazer 330 brake issue????
Old Sep 9, 2012 | 06:38 PM
hslag's Avatar
Default 2010 rail lazer 330 brake issue????
guy's i am new hear and looked around and did not see anything like this posted so hear it goes..I JUST BOUGHT THE BIKE AND NOTICED THE REAR BRAKES WHERE WORE OUT SO I GOT ME THE PADS AND put them on and by the way before this rear brake pedal was soft now the rear brake caliper will not work at all ther is no pressure even after bleeding severial times by the way there was no fluid in rear resivior,the handle bar brake lever is real hard like the caliper is stuck and fluid pressure is not holding on the rear pedal any thoughts guys thanks in advance.ps 1 more thing are they worth rebuilding our do you reccomend replacing them??
Old Sep 9, 2012 | 07:46 PM
Welcome! Trail Blazer 330 front and rear brakes work together and split going to the small rear master cylinder. Have had problems with the foot bake over the years,especially if they aren't used much. May take a little time,but keep trying to bleed the rear brakes. Works best if you have a vacuum pump to pull the fluid/air out of the caliper. Possible the rear master cylinder needs replacing if you can't bleed it.(no rebuild parts available). If the front brake master cylinder is frozen,piston and seals kits are available. Look here under your model at how the system works on brake parts and replacement part #'s. Browse Also Cycle Parts Warehouse and Cheap Cycle Parts are cheaper sources for parts rather than most dealers.
OPT
Old Sep 9, 2012 | 07:50 PM
hslag's Avatar
Ok thank I will yum bleed tommorow
Bratman2
Jul 25, 2015 07:16 PM
Gtsordo
Jul 22, 2015 01:27 PM
Yamadude1031
Where to Ride
Jul 16, 2015 02:13 PM
toonces
Jul 11, 2015 12:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
