Needs choke to run
Old Sep 11, 2012 | 08:47 AM
keithert's Avatar
Default Needs choke to run
My son's 90cc ATV with a PZ-21 carb won't run without choke. I put on a new carb a year and a half ago. Does it likely just need a new jet from a rebuilt kit?
Old Sep 13, 2012 | 11:11 AM
Jaster94's Avatar
have you tried cleaning it first?
Old Sep 13, 2012 | 11:19 AM
keithert's Avatar
I've put Seafoam in the gas and also sprayed carb cleaner into the carb. I have not removed the jet and tried to clean it. I'll have to try that but haven't had good luck with cleaning them in the past. Thought it might be more worthwhile to just replace the jet.
Old Sep 13, 2012 | 11:30 AM
Jaster94's Avatar
so the carb ran great for 18 months and now it's acting up?
Old Sep 13, 2012 | 11:34 AM
keithert's Avatar
Pretty much. It's been getting steadily worse over the last few months.
Old Sep 13, 2012 | 11:40 AM
Jaster94's Avatar
well if it ran good then performance deteriorated, i'm unsure. surely the jet is the right one for your elevation, right? i mean, the choke richens the mix, so unless you have a vacuum leak, it'd be a jet issue, right? quick test, get it running, spray ether/starting fluid around intake boot and see if she revs up.
Old Sep 13, 2012 | 11:48 AM
keithert's Avatar
Couldn't the jet just getting more and more clogged?
Old Sep 13, 2012 | 11:53 AM
Jaster94's Avatar
if the jet was getting more and more clogged, you couldn't rev it up, it would start bogging down with more throttle.
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
