OPT QUESTION for you
Old Sep 12, 2012 | 11:12 AM
diamonbird's Avatar
Default OPT QUESTION for you
What does the Thumb throttle box do or what is it there for?
Old Sep 12, 2012 | 01:51 PM
It houses the throttle cable along with the etc switch(electronic control switch). Keep throttle slack no more than 1/8" at the thumb lever or the etc switch contact points can touch and the atv will die at idle or pop back through the exhaust coming down from a high rpm. It's main function is in case the cable is snagged by a limb,etc, it will limit the rpm. It's just a safety switch. http://www.partshark.com/custompage3.asp?pg=polaris Try here for a manual that might help on this along with the clutches. OPT
Old Sep 12, 2012 | 08:38 PM
diamonbird's Avatar
Thanks OPT, I understand!
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
