Electrical problems
I have a 2000 polaris explorer 250 4x4. My 4 wheel drive does not work. I have taken apart the switch and i'm not getting any power to it. What can or what should I do next. I took it to a polaris dealer and was told it would cost 1000.00 to fix it. The machine probally isn't worth that much and I just don't have that kind of money. Can you walk me through a little at a time to fix this problem? I should also let you know my battery very slowly goes dead. When I started having problems with the battery the 4 wheel drive worked fine, but I was having issues when I would put it in reverse the machine would kill. That problem seems to have gone away. I,m think I'm out of my league, please can you help me?
You have your AWD magnetic coils on each of your front strut housing, check the wires to see if they are not damaged and check for battery voltage. The dealer is probably thinking this is the problem, and it takes awhile to fix, so most of that would be labor cost. you can also check your override switch. the override switch serves 2 things, it allows you to engage the AWD in reverse, and provides additional power when going in reverse. This could have caused your reverse problems.
Thanks OPT the forward gear switch is now sending power to the awd switch. The reverse is not, could this be a bad switch. I have taken the strut apart and with the switch on in forward gear I have noticed a more powerful magnetic pull from the hub coil. I was told if the coil works the wheel will not turn at all if the rear wheels are on the ground. I have only taken off my right strut and my left is still together. My wheel is still easy to turn on the left side what does this tell me?
ranvette
Jul 4, 2015 06:13 PM
