Polaris 500 oil change
Old Sep 25, 2012 | 01:29 PM
Slickman's Avatar
Default Polaris 500 oil change
Time to change oil on my 2006 polaris 500. Never did it before. Any help appreciated
Old Sep 25, 2012 | 02:17 PM
Welcome! Easiest way to do it(without having to pull the sump drain bolt also) is drain the oil tank,leave the old oil filter on,crank the engine for 15 seconds only and kill! The sump oil will drain out of the oil tank. Replace the oil filter,add 2 quarts (Polaris PS4 Plus oil,0w40 Mobil1,or Amsoil 0-40),run at least 4-5 minutes,kill it and check the oil level with the dipstick screwed all the way down. If this machine is new to you and you don't know it's history or oil use,you can also remove the oil screen fitting from the back of the tank and clean if necessary. Use teflon tape,pipe sealant,etc on the threads and screw back in lining the valve neck with the mark on the tank. I would clamp off the top vent hose on the tank with vice grips close to the fitting for a couple minutes and remove. This gets the oil to the pump quicker. 2 quarts is all it takes,don't overfill. OPT
Shifts
14
Jul 13, 2015 08:41 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
yambam13
Jul 4, 2015 01:49 PM
