HRC cam for 400EX?
Old Mar 21, 2001 | 05:14 PM
GrimReaper's Avatar
Anyone using this cam? What are your opinions on them? Power gains?
Old Mar 22, 2001 | 10:46 AM
TrailMix's Avatar
I just put one in my 400EX a couple weeks ago. It isn't broken in yet so I can't tell you how well it works yet. Right now I'm running it with a new 10.6:1 86mm JE piston, K&N, e-series slip-on, 14 tooth sprocket, and the stock carb. So far I am very impressed with the performance even though I have been trying to take it easy. It revs much quicker and pulls way harder than before. This cam is from a power-up kit for the XR400 and they claim the kit gives the XR400 15% more power across the entire power curve. (Other components in the full HRC kit are a 11:1 piston and clutch upgrades). I think that this cam alone will give you at least 10% more than an XR400 cam. Also, XR's Only sells a copy of this HRC cam for about the same price as any other after-market cam. The genuine cam is pricey though- $280 to $400+ depending on where you look.
Old Mar 22, 2001 | 11:13 PM
GrimReaper's Avatar
Did you get the copy or the real deal? Whats the differance between the two besides the ovious? Do you have to use hardened rockers or heavy-duty valve springs? I wonder if this cam is any better than my Web-cam 450/451 grind?
Old Mar 23, 2001 | 12:17 PM
TrailMix's Avatar
I got the real deal from Service Honda for $277. Before getting the HRC cam I bought a used 450/451 WebCam for real cheap -but never actually used it because it alreay had too much wear. The HRC cam is much thicker than that WebCam- I mean the diameter across the lobes is about 1/8" more than the WebCam. It also comes with the decompression feature- which is nice on a cold day when the 400EX can be hard to start. XR's Only claims that you don't need hard faced rockers with their copy cam. I got the hard faced rockers anyways, just to be safe. I didn't get new springs because I figure that next year I'll get a port/valve job and take care of them then.
Old Mar 23, 2001 | 04:37 PM
GrimReaper's Avatar
Trailmix, let me know what you think of the cam as soon as you break in the motor and open "her" up.
Old Mar 27, 2001 | 02:48 PM
MIA400EX's Avatar
TrailMix,
How much is the HR Cam that you use?
Do you have a Honda Part # for it?
Did you order it on-line?
Do you need to upgrade any other internal parts (valves, springs, etc) in the engine if you use this cam in a 400EX?
Thanks for any info / help on this...
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
