problem
Old Oct 8, 2012 | 06:06 PM
hvfdp23's Avatar
Default problem
I have a 1996 Polaris 400 4x4 and all of a sudden it quit tore the carb off cleaned it still nothing, new fuel filter nothing. My dad has an identical one and it is a lot zippier, mine has never been that good. Any ideas?
Old Oct 8, 2012 | 06:26 PM
Welcome! Check the simple things first,may be just a fouled plug since you said it wasn't running right? Also do a compression check and check that you have good spark. If compression is lower than 120 psi,possibly time for a new top end,etc. OPT
Old Oct 8, 2012 | 06:29 PM
hvfdp23's Avatar
I go through plugs like crazy. If i ride all day long I use at least one plug.
Old Oct 8, 2012 | 06:34 PM
Well you said you "cleaned" the carb,but did you replace the needle and seat (bad on this model for wear) Plus like I mentioned earlier,a compression test will show you which way to go whether it's fuel related causing plug fouling or low compression causing problems.. OPT
Old Oct 8, 2012 | 06:37 PM
hvfdp23's Avatar
compression test is my next step, im plannin on doing the top end this winter. I rebuilt the carb as well.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
