EBS clutch options for 2012 400HO?
Old Oct 9, 2012 | 04:50 PM
WilliamBos's Avatar
Default EBS clutch options for 2012 400HO?
Found out today that the 400HO EBS kit has been discontinued, and the 500HO kit will not work. What are my options, as I would really like to add EBS to my bike come spring.
If used clutches are my only option, what do I look out for? Are both Primary/Secondary fully rebuildable?
Old Oct 9, 2012 | 05:06 PM
Who said the 500 ebs kit wouldn't work? Both the 400 and 500 crank shafts and rods have the same part numbers along with both having the same gear case numbers. Clutch mounting shouldn't be a problem?? OPT
Old Oct 9, 2012 | 05:15 PM
WilliamBos's Avatar
A Polaris dealer that I came across through another forum. Said he asked the techs, they sad no. I thought the same as you, should be the same bottom end, just a different jug, head, and piston, correct?
Thanks OPT.
Old Oct 9, 2012 | 05:39 PM
Yeah,as far as I can see just the cylinder and piston is the difference? Look here under the 2012 400 and 500 and you check it out. Browse OPT
panicmanic
Sep 28, 2015 12:59 PM
rgjackson
Sep 17, 2015 11:21 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
greg74
Sep 10, 2015 07:58 AM
cdstang
Aug 31, 2015 07:52 AM
