400EX help!!
Old Oct 18, 2012 | 03:27 PM
savage5480's Avatar
Default 400EX help!!
I tore apart my 400ex to replace the valves because the guy i got it from didn't do the timing right. So i got two more sets of valves on and set the timing right by turning it clockwise then it wouldn't start so i found out that it was suppose to be turned counterclockwise i took it back apart then saw that the two intake vales were sticking out then i looked at timing chain and found out that the tensioner was all the way out. So i replace the valves turned it counterclockwise to the mark put all lobes down and tried again and didn't work. I took the rocker head off and spun flywheel counterclockwise to the t mark and lobes were up.
I think that the timing chain is stretched but not sure.
Old Oct 18, 2012 | 06:34 PM
jgar's Avatar
Its common for the cam chain to stretch. When you replace it inspect the guides. If they look worn replace it.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
