are the 2004.5 600s free of this recall?
Old Oct 26, 2012 | 12:45 AM
sportszillasheex's Avatar
Banned
Default are the 2004.5 600s free of this recall?
http://gh-ftp.com/ORV%20Manuals/Pola...tion%20Kit.pdf
Old Oct 26, 2012 | 08:06 AM
TLC's Avatar
TLC
A 2004.5 is concidered a 2005, I know it did not get by this ECM recall Polaris Industries Expands Recall of ATVs Due to Fire Hazard
Old Oct 26, 2012 | 10:04 AM
Originally Posted by sportszillasheex
The pdf you show is just for the ignition update kits on the 600 and 700 carb models from the Ducati system to the more dependable Kokusan electronics. These kits do not supercede the recall on all the "Black" ecm Chinese modules that were defective. If you still have this module have it replaced. OPT
Old Oct 26, 2012 | 11:25 AM
Banned
right my question was when did they start manufacturing them with the better ignition setup? i heard only 03s and earlier were effected so i figured id ask you opt
Old Oct 26, 2012 | 11:26 AM
Banned
no i think a 2004.5 is considered a 2004.5... the 2005s got the updated styling and better front suspension among other changes, but yeah i know what you mean. the ecm wasnt my question
Old Oct 26, 2012 | 12:00 PM
Basically all 600 and 700 carb models from 2002 to 2004 were equipped with the Ducati ignitions. Latter part of 2004 is when they were first doing the swap in ignition systems for the 600 and 700 to Kokusan.If you had a model built after September I think,the Kokusan was installed. Last year of the 600 model built was in 2005. Last year of the carb model 700 was 2006 and the 700 efi remained until 2007 when it was dropped from the line in favor of keeping the 800 efi. You can tell real quick as to what system you have. Just pop the front panel and if you have "coil pack" combo cdi and coil that says Ducati you will have problems! If you have separate cdi and coil you have the Kokusan system.OPT
Old Oct 26, 2012 | 12:28 PM
Banned
thanks opt. and by the front panel you mean the (as i call it) "alligator nose" piece under the headlight pod by the front rack, correct?
Old Oct 26, 2012 | 12:33 PM
Correct. OPT
Old Oct 26, 2012 | 12:39 PM
TLC's Avatar
TLC
I know its not your question but if your getting one recall done you might as well get them all done.
A 2004.5 is either considered a 2004 or 2005 on recall lists. They have the 2004 and 2005 SP500 both on the list,not sure how a 2004.5 could slip by it.
Old Oct 26, 2012 | 12:57 PM
The ignition system wasn't a recall if he needs one. Should have been,but Polaris slipped this to the customers dollar! I had a lot of complaints on this,but couldn't help even when I called Polaris! Problem is almost all the ones that I replaced went out after the warranty period,some could go a few years before they acted up,then is when Polaris took notice and changed the ignition system! Even I was taken by surprise when I ordered my first stator that showed bad and saw that it had changed to a kit number instead! OPT
