Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
LT80 Oil On Drive Belt
Old Nov 11, 2012 | 08:02 PM
yfz_duner's Avatar
Default LT80 Oil On Drive Belt
I've got a 2006 LT80 that's stock and has always run great. Last week I was checking it over to get ready for the season and it won't go. The motor runs fine and revs, but the power isn't getting to the rear wheels. I suspected something with the belt, so I took off the left side inspection cover and there is some oil in there and it has gotten on the belt causing it to slip.
Not sure where the oil is coming from. While cleaning the air filter I vacuumed out the remaining sand from the air box. Could I have pulled a vacuum and sucked oil in from somewhere or is this just a coincidence?
I checked the oil injection pump and it doesn't appear to be leaking any down into the case. So where do I go from here? Any ideas? I searched this forum and the internet and all I've found is a mention of "the gear box gasket (under the rear clutch)." Could this be it?
speedbuff
13
Nov 11, 2020 10:16 AM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
