Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
50cc atv hard to start
Old Dec 17, 2012 | 07:05 PM
tony ferguson's Avatar
Talking 50cc atv hard to start
I have 50cc quad , It has been very temperamental from day one. It takes alot of cranking over to get it running. I have good spark . Today I pulled the spark plug and shot a seringe of gas in the cylinder. Tried to start it and same senario. It will eventually crank over after 8-10 minutes. I usually have to put a charger on it after so many cranks . Not sure what to check next. Any help would be appreciated . Happy Holidays !
Old Dec 18, 2012 | 06:03 AM
Jaster94's Avatar
Merry Christmas! it sounds like your valves need to be adjusted for a hard starting/cranking problem. surely it's getting plenty of fuel. i'd look at the valve clearances and check compression with a gauge, not your thumb.
Old Dec 18, 2012 | 08:46 AM
LT80's Avatar
LT80 Expert
What machine is this? 2 or 4 stroke?
Old Dec 18, 2012 | 07:57 PM
Jaster94's Avatar
thanks for the reminder..... i promised not to answer any more 50cc questions because of the 2 stroke factor possibility. ......
Old Dec 18, 2012 | 08:41 PM
It's a fourstroke. The brand is yangking or something like that . It was originally purchased from Alien Motorsports out of Reno, Nevada.
Old Dec 18, 2012 | 11:30 PM
LT80's Avatar
LT80 Expert
I'd clean the carb.
If that don't work, I'd do what Jaster said.
Jaster: please keep replying....Bet you ask next time.
Being a 4 stroke, you can take over.
Old Dec 19, 2012 | 04:59 AM
Jaster94's Avatar
I'd clean the carb.
yeah, first question WILL BE: 2 stroke or 4?
Old Dec 19, 2012 | 05:47 PM
So I checked the valve clearances and still same issues. When I pulled the exhaust valve cover (cap) , there was a considerable amount of oil and gas mixture inside. Is that normal or ring problems ?
Old Dec 24, 2012 | 03:12 AM
rjenx's Avatar
Also check your air filter, and spark arrester in exhaust to make sure they are clean.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
1000gade
May 27, 2015 12:37 PM
dcoleman
Oct 5, 1999 01:34 AM
dunc_n
Aug 26, 1999 09:32 PM
