96 sportsman swingarm frame holes worn out???
Old Dec 18, 2012 | 01:25 PM
cmichales's Avatar
Default 96 sportsman swingarm frame holes worn out???
What is the best repair for the frame when the swingarm bolts wear into frame so the whole swingarm is loose. Should I weld in grade 8 washers? Does polaris sell new ones to weld in?
Thanks,
Old Dec 18, 2012 | 01:40 PM
Just replace the worn bushings! I've replaced plenty of these. The replacements are stronger,just like your clutch cover! You may need to replace both the plastic and steel bushings depending on the wear,plus bolts if needed. Items #14 and 15. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
95wolv
Jul 21, 2015 12:25 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Coryco
Jul 6, 2015 07:30 PM
