2002, 350 Honda Rancher ES
Replacing choke cable. Clymer service manual reads, after removing all hoses, guards, clamps, ect.. loosen 14mm nut on carb and remove cable.
The cable will not come out. Something internally still holding it in???
This is normal when choke is stuck..You will have to be patiance an spray some carb spray around choke value an keep wigging choke value little at a time.becareful an not break choke value off....
