Need to know
Old Jan 20, 2013 | 06:06 PM
Dritto's Avatar
Default Need to know
What is this noise?
My 400ex does this same noise, and only has been ridden for about 55 hours. It's very annoying.
*Not my video*
Old Jan 20, 2013 | 07:52 PM
jgar's Avatar
1) What mods do you have?
2) When was the last time you adjusted the valves?
Old Jan 20, 2013 | 09:03 PM
Dritto's Avatar
Twin Air Filter, otherwise performance stock
Old Jan 20, 2013 | 09:53 PM
jgar's Avatar
When was the last time you adjusted the valves? Does it make the noise with the stock filter on?
Old Jan 20, 2013 | 11:59 PM
Dritto's Avatar
I've never adjusted them. I think the sounds comes from the top of the cylinder, and not the carb.
Old Jan 22, 2013 | 06:29 PM
jgar's Avatar
Put the stock filter back on and see if it makes the noise. Mine did made a similar sound when put a uni filter on and did not rejet the carb. She was running real lean with just a air filter change. We you run lean there is a tremendous amount of heat created and it can burn up your top end.
It would be a good idea to adjust the valves.
