can i run a 2003 predator without fuel pump
i just got a predator 500 and it runs great and looks great. but when you get after it its like it runs out of gas and spits and stutters then dies. it will start back and you can ride it all day easy but thats no fun. what can i do or what could it be? please help?
Carb works on vacuum from the fuel pump to draw in the fuel better.Plus carbs are often the same height as the tanks making the fuel pump necessary in a lot of machines. It may not always be a fuel pump problem when it dies on you. Could be a vent line is partially blocked,needle and seat may have some trash under it reducing fuel flow. Even the fuel valve itself could be the problem.Could have some trash in the carb. Eliminate these as the problem. You can also pull the fuel line from the carb and crank the engine over to see if you have a good pulse of fuel from the pump. OPT
I would still check out the carb,plus even the fuel valve internal filters could be partially stopped up,causing problems. Something is causing it to die. Either a fuel blockage,vapor lock until it gets another "gulp "of air,plus make sure the problem isn't electrical related,loss of spark when it does this. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
OPT
house1
Aug 9, 2015 10:49 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
