Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
2001 Eton No Spark
Old Feb 9, 2013 | 09:40 PM
12311954's Avatar
Default 2001 Eton No Spark
I have a 2001 Eton DXL 90 that has no spark. There are 6 wires going to the CDI, white/blu,brn,black/white,blk,blk/red,blu/yel. Stop switch good. Where do I start?
Old Feb 10, 2013 | 06:08 AM
Jaster94's Avatar
try a new spark plug yet?
how about checking the rear tether kill switch if applicable?
your kill switch is ok?
check your kill switch on your keyed ignition?
not just the run/off/run switch on the left handlebar, but your keyed ignition switch. sometimes those wires come loose or ground out.
Old Feb 10, 2013 | 07:09 AM
12311954's Avatar
Default 2001 Eton No spark
No teather switch on this one. New plug. Is there a test procedure for ignition switch? It seems to energize power to everything like it should
Old Feb 12, 2013 | 08:26 PM
12311954's Avatar
Default 2001 Eton-No Spark
are there any other troubleshooting diagnostics i can do on this machine?
Old Jun 21, 2015 | 05:30 AM
Carver Sloan's Avatar
I have a 2001 E-Ton Beamer(49cc). Had the same issue, no spark. I replaced the coil, the cdi box went through the entire wiring harness, pulled half my hair out and considered setting it on fire before i figured out it had a bad stator.
I don't know about your specific model, but the stator on mine is unique. Just a random OG or Minerelli type stator won't work. If your stator is bad yer gonna have to spend the $120.00 for an E-Ton specific stator.
Old Jun 21, 2015 | 08:00 AM
Jaster94's Avatar
http://02e3acd.netsolstores.com/e-tonparts.aspx
Anything atv.com
Ramman1
Aug 11, 2022 01:53 PM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ramman1
Jun 16, 2016 09:07 PM
Hunter100us
Oct 7, 2015 11:46 PM
maxjung
Jul 14, 2015 03:10 AM
