which one is better??
Old Feb 24, 2013 | 08:24 PM
BEC300ex's Avatar
Default which one is better??
i have found some alright deals on a few 4x4 fourwheelers, which one yall think is the best route, if you can list the pros and cons in your opinon, or if you think a certain one sucks. anyway they are a 2004 vinson suzuki 500, 1999 artic cat 500, or a 1999 yamaha 600 grizzly. thanks guys
Old Feb 24, 2013 | 09:43 PM
Ms8091's Avatar
I would go with the AC first, the vinson and then the grizzly. The AC is about the same as mine, well balanced, 5 speed semi auto, good power and reliable. The vinson is similar, I believe it's auto or at least most of them are. They are kind of a watered down version of the now KQ 500's. I have read a lot of bad about the grizzlys, and I have no experience with them, just what I read. Hope that helps.
Old Feb 24, 2013 | 10:51 PM
user493's Avatar
Moto Psycho
I would go with the Suzuki just because it's 5 years newer than the other 2. If you want a Grizzly the 660 is way better than the 600.
Old Feb 25, 2013 | 10:14 AM
I'd also go with the Suzuki first. I believe the Vinson is just a straight axle version of the King Quad which is independent rear suspension (IRS). IRS is a more comfortable ride with better ground clearance. Straight axle rear is easier to kick out in high speed corners.
Old Feb 25, 2013 | 11:52 AM
1eep's Avatar
Vinson was around before the King Quad replaced it. Yes it is a straight axle and the one sitting in my garage is a semi auto, not belt.
Old Feb 25, 2013 | 11:53 AM
TLC's Avatar
TLC
Get the Vinson is this shootout the it hands it to the 500 Arctic Cat, Reviews of Motorcycle, ATV, Snowmobile and Watercraft vehicles
The 600 Grizzly was a short lived ATV before being replaced by the 660 Grizzly.
Some say the motor was to big and powerful to be a air/oil cooled.
Old Feb 25, 2013 | 11:39 PM
BEC300ex's Avatar
i was also thinking the suzuki but im also fond of big motors, so with that being said whats wrong with the grizzly 600? if i can get my hands on a grizzly 660 its not a question ill go with it but now between the vinson and grizzly 600 which is faster? does the 600 heat?
Old Feb 26, 2013 | 06:19 AM
Ms8091's Avatar
The grizzly 600 didn't last too long and from the reviews I read, there were reasons. Just not glowing reviews, but it doesn't sound like it was a piece of junk.
Old Feb 26, 2013 | 08:20 AM
mudslinginfool's Avatar
Does it in the Mud!
vinson or arctic cat. Arctic cat used the suzuki motors up till around 2008,then they built their first very own 650H1. The Vinson has a solid rear axle (SRA) and seemed to be a pretty good atv back in the day. cant remember if there were any full auto vinsons.
The arctic cat had a semi auto clutch, toe/heel shifter with full floor boards. the vinson may have had the floor boards also,cant remember. Cat has a semi independent rear suspension. It was a solid rear axle but was equipped with Two shocks to act a little more like an independent suspension. also a pretty strong bike back in them days.
Never seen a 600 grizz,and probably for a good reason as others stated. 660 griz is everywhere now.
both vinson and cat were full time 4wd up till 2001. I know there was a lever kit for the 1999 250 4wd arctic cat models. if you bought the kit it allowed you to select 2wd or 4wd so there may have been a kit for the 500.
Last edited by mudslinginfool; Feb 26, 2013 at 08:30 AM. Reason: mis informed. corrected my wording.
Old Feb 26, 2013 | 08:25 AM
1eep's Avatar
there are some vinsons that were automatic, i havent personally seen any. The semi Auto vinson has a low range on the tranny, i have one and use the machine around the yard, that low works great for towing large loads of firewood.
Yes, the vinson has full floor boards.
