cooling fan help for 400ex
Old Mar 12, 2013 | 02:25 PM
07honda400ex's Avatar
Default cooling fan help for 400ex
does any one know where get to a waterproof fan for 07 honda400ex.
Old Mar 12, 2013 | 02:30 PM
bluegizmo83's Avatar
Your looking for the Spal 4" Puller Fan. Just search google and you will find some. You can also find them on Ebay sometimes.
Old Mar 12, 2013 | 02:39 PM
ok thanks ill go look it up
Old Mar 14, 2013 | 08:30 PM
do u think a fan or a biger oil cooler would work better
Old Mar 14, 2013 | 08:36 PM
Fan, definitely! A bigger oil cooler does help, but a fan will help much more because not only does the fan help cool the oil cooler, it also blows more air across the cylinder head which also helps with cooling.
edit: Unless you do most of your riding at high speeds...? If you ride at high speed 90% of the time, then a bigger oil cooler would probably work better. But if most of your riding is done at low to mid range speeds then go with the fan.
IMLN
Sep 28, 2015 03:32 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
