Cam Chain Tensioner Tool
Old Mar 17, 2013 | 02:16 PM
jampg's Avatar
Default Cam Chain Tensioner Tool
Do I need one or can some other tool be used. This is for an 03 Predator.
Thanks.
Old Mar 17, 2013 | 09:00 PM
Thin bladed screw driver can be used. If you remove and replace the tension,turn the tensioner slot to remove the spring pressure. Hold the screw driver and tensioner with one hand and install the two mounting bolts,then let the screw driver slowly find the stopping point against the cam chain, then replace the sealing bolt.Best I can remember on the Predator.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
raman8tor
Sep 20, 2015 07:35 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
