The impossible
Old Mar 19, 2013 | 02:56 PM
Fmarshall04's Avatar
Default The impossible
I have this NO NAME 90cc atv. Guessing that because of the 87ccm stamped on the jug. Any way I have spark,fuel getting through carb and into the cylinder. Valves are at .003. Double checked those. The remote control "board" is crap all corroded. It will 1 in ever 100 times think of starting, normally if I have left it alone. won't start on ether either. There is not a single ID marker on this thing. It does have the typical Honda knock off engine. I have the Honda Manual for that, but am out of ideas!!!!!!! the only other thing is there are 3 wires where a rear brake light used to be? or a kill sw. with key on 1 is hot the other 2 ???
Old Mar 19, 2013 | 03:35 PM
Airb's Avatar
You can try gaping the spark plug to the proper specifications in the owners manual. Best of luck.
Old Mar 20, 2013 | 07:07 AM
Ok letting it sit overnight it started this morning ran for about 15 sec on choke . So I could assume that valve and electronics are ok . So what gives, why an overnight rest would it start????
Old Mar 20, 2013 | 11:11 AM
armagh's Avatar
Maybe you should think about getting rid of the crappy corroded remote and go from there.
Old Mar 20, 2013 | 11:20 AM
It ran with the board plugged in, so must not be an issue??? No clue
Old Mar 20, 2013 | 12:32 PM
LT80's Avatar
LT80 Expert
I think it may have been flooded. Sitting allowed the fuel to seep by the rings.
I'd clean the carb (remove the jets too) paying special attention to the float needle/needle seat.
Old Mar 20, 2013 | 01:43 PM
armagh's Avatar
You said it ran for 15 seconds... Did you turn it off OR did it just die on it's own?
It was you that said; The remote control "board" is crap all corroded... By "remote control "board"" , I am guessing you are talking about a device that allows someone to start or stop the engine from a distance. .. If it was me, I would disconnect the remote on the bike and see if that stopped all the magical or impossible stuff that is going on.
Old Mar 20, 2013 | 02:05 PM
All set the coil wire was cut or torn who knows! When I held the plug to the head it was fine, but as soon as i installed it was N/G... Found it with a shock!!! Thank you all for your info regardless!
Johnny Mac
Aug 15, 2019 03:13 PM
Jason Poulin
Sep 20, 2015 02:49 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Polarisman1123
Aug 3, 2015 02:08 PM
trx250Rob
Jan 7, 2002 12:02 PM
