Need help with honda 185s!!!!!!
Old Apr 2, 2013 | 08:04 PM
07honda400ex's Avatar
Exclamation Need help with honda 185s!!!!!!
HI,my friend bought a 1981 Honda 185s 3wheeler for 100 bucks a while ago and we got it running than tore it all apart to restore it and after we restored it we put everything back together and it got only little spark so he got sick of it and sold it to me for the same price he bought it for. I THINK I GOT IT TO Get good spark because I cleaned the connections and stator but and has blue spark but, it wont start and it has good compression but I don't know what its a post to be at. I ALSO clean the carb and adjusted the valves and me and my buddy tried pop starting it and we even put lil gas down the head and still wont start but it started once for 3 sec's. Do you have any ideas how to fix this problem because I want to fix it and make some good money on it. Thanks
Old Apr 3, 2013 | 05:53 PM
Stapleton1184's Avatar
1st check your grounds then your spark plug, wire, coil and boot also if you did valve lash double check it and check your timing if you have good spark all you need is is air fuel and comp.
Old Apr 3, 2013 | 08:26 PM
And fire
Old Apr 3, 2013 | 08:57 PM
thanks I got a cdi from friend today but still wouldn't start and tried new plug and first pull it started!!!!!! even though old sparkplug had spark but apparently not under compression. thanks for help!!!
Old Apr 3, 2013 | 09:05 PM
No problem
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
