Clutch cleaning questions?
Old May 10, 2013 | 08:35 PM
WilliamBos's Avatar
Default Clutch cleaning questions?
Does it matter what scotch brite pad I use? green? red?
If I have no brake cleaner, whst else can I use? Acetone? Varsol?
Attached Thumbnails Clutch cleaning questions?-spring-cleaning-2-1-524810445.jpg
Old May 11, 2013 | 04:25 AM
If it's just general cleaning use compressed air first to blow out most of the belt dust in an open area. This helps the most. If you want to break the "glaze" on the clutch sheaths just use the plain old old green Scotch brite pads and cheap Walmart Super tech spray brake cleaner. Try to stay away from the fiber washer.Lacquer thinner,acetone,etc are a little too "hot" to use around some plastic parts.
Old May 11, 2013 | 01:26 PM
WilliamBos's Avatar
Thanks OPT. I will post pics when I get it apart and blown off. It is only a year old, so may not need the sheaves serviced.
Old May 11, 2013 | 03:03 PM
Only a year old! I'd just blow the dust out and keep riding!
Old May 11, 2013 | 03:16 PM
WilliamBos's Avatar
Thanks OPT!! Will do. Going to take cover off now, and will grab pics.
Should I wrestle the belt off before I blow it out?
Old May 11, 2013 | 03:37 PM
Just pull belt up from the middle to get slack and walk it off the rear clutch(replace it facing the same way),then you'll be able to push the front clutch in and get into all the crevices with the air gun. Just hit the rear clutch in the middle with air and dust will fly everywhere from inside the helix area. Just be in an open area when you do this.
Old May 11, 2013 | 04:29 PM
WilliamBos's Avatar
Got them all blown off...
Much better. May do them again come fall.
Old May 12, 2013 | 07:15 AM
TLC's Avatar
TLC
Looks awsome,I,d just put the seat on and call it a day.Has a mean mechanical look.
Old May 12, 2013 | 01:32 PM
Bing43's Avatar
I always wonder why there's not some type of filter on the intake side of clutch housing. All the dust in there can't be good on the clutches. I blow mine out a lot for sure after a dusty ride.
Old May 12, 2013 | 03:19 PM
WilliamBos's Avatar
I know. It has got a terminator look to it.
